Refuses to turn on
For some reason my X20 will not simply turn on. I have charged the battery still nothing Help please
좋은 질문입니까?
좋은 질문입니까?
Have you tried pressing the play button to turn it on?
이 답변이 도움이 되었나요?
Hello Andrew 6, I have same problem and when I press play button it starts playing the photos but the switch is of. If I switch on it will not do anything, could it be this fuse? Thanks in advance
I’ve had exactly the same problem on my X20. I followed the disassembly guide and traced the fault to a blown fuse on the main board, a tiny SMD fuse in 0603 package. I believe this is rated at 2.5A. I’m going to replace it and if it works I will add a replacement guide. Hopefully there are no follow-up faults.
I’ve replaced the fuse on the PCB and reassembled the camera - it is working absolutely fine now! I've added steps to the disassembly guide to show where the fuse is located.
이 답변이 도움이 되었나요?
Where is this fuse located? Is thid fuse easily available?
지난 24시간: 0
지난 7일: 3
지난 30일: 30
전체 시간: 1,344
