주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
526 질문 전체 보기
Why has my screen gone weird?
My s4 appears to be behaving normally except for the screen. When the screen is activated, it shows a steadily increasing array of mostly green, but also red and blue, dots. It doesn’t show anything else at all. When this first happened yesterday, I also noticed that the phone had a bulge in the middle of it - the battery had swollen up. So I removed the battery, left the phone overnight, and the next day when I put the battery back in and turned the phone on it was fine. SO, I just installed a NEW battery, but after working fine for about 10 minutes, the screen is doing the same thing as before.
I have tried opening up the phone and the bit that connects the screen to the motherboard seems to be clipped in fine.
Has this happened to anybody before? If I intall a new screen will it work? Or is something else causing the problem?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@pbsk
the display was most likely damaged by the expanding battery. Replacing the display should fix this Samsung Galaxy S4 Display Assembly Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jack 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 69
