주요 콘텐츠로 건너뛰기
Cordless hand held vacuum manufactured by Black and Decker in 2017. This can be identified with model number: BDH2000PL
16 질문 전체 보기
Loosing power after 30 seconds of use?
Unit is 2 years old with light use. Battery is fully charged, however unit is working properly only for bout 20-30 seconds after that seams to be losing power. Powering on and off the unit gives another 20 seconds of use. By switching on and off it can function like this for some time.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 9개
Hello,
I have the same problem with the DV1815El-QW , 2 years old! Lithiumm battery should works more than 2 years!!!
I am also looking for battery replacement.
Do you know where I can find them?
LGDAHB71865
Thanks
I´ve got the same problem.
Looking for the same batteries
Why do people tell everyone they have the same problem to a question that has been already asked? You are supposed to provide answers here not tell us you have the same problem. I see this over and over and its annoying as Hillary.
Sorry for the inconvenience, just looking for alternative batteries
Slappy ! You are well named and I laughed out loud......there is a circuit board attatched to the battery, my advice? Skip it ! BUY a new one with replaceble batteries!
댓글 4개 더보기
댓글 달기
답변 6개
선택된 답변
Thanks everyone for your feedback! Replacing the batteries solved the problem in my case.
Original batteries weren’t available when I was searching. I managed to swap the batteries with the “SAMSUNG-30Q-18650-3000-FLAT“. So far everything works perfectly.
해당 답변은 도움이 되었습니까?
점수 4
댓글 7개:
By Swap - do you mean dropped them into the plastic container and all was well, or did you have to cut/soder/finagle?
By 'swap' I mean cut / replace & solder the new batteries
How many batteries all together for this unit?
I just opened up my 20V Pivot, and it also has 5 of the batteries.
Hi, I used the same model battery SAMSUNG-30Q-18650-3000-FLAT (with solder tabs) but only replaced the one offending cell that was failing. You can determine this by measuring the temperature of the batteries during the 30 second running of the motor. Just as the motor would stop one of the cells was reaching a temp > 110 DegF using IR, while the others were ~ 90. Cut and replaced that cell and working well now.
댓글 2개 더보기
댓글 달기
@soryn
this sounds like a battery that is starting to fail. It may charge but does not hold a charge. I’d replace the battery and then re-evaluate. Black and Decker Pivot MAX Battery Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Sounds very probable, will try to find and replace the battery. Thanks for your help!
Unit uses 5x LG HB7 18650 1500mAh 15A Battery "LGDAHB71865 - P091C313A1". I can't seam to find these exact batteries to replace, any idea of a great alternative and/or were to buy them? Thanks
you can find those @ IMR batteries .
댓글 달기
It`s normal that after 2 years of charging/recharing , bateries lost it`s performance. But it`s no problem to exchange beteries. In this vacum model you need to buy any Li-Ion 18650 bateries (5 pieces for 18V model) . You need to remember only, to buy orginal bateries: (LG, Panasonic, Samsung etc). LG are dedicated for this modl but can be any other Lithium !! Capacity between 2500 - 3500 mAh Vacum has biulded BMS module only for this king of bateries. Exchange is very simple for each person who have basic knowledge about electronics or buildings RC battery package.
https://d3nevzfk7ii3be.cloudfront.net/ig...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The 18650 Li-ion is becoming  very common and can be purchased even at Walmart.  However be sure to buy them with the proper terminal for your use.  The standard ‘D’ or ‘AA’ ends that fit into a holder like a flashlight or TV remote shold not be used in a tool that requires a ‘tab’ on the battery for soldering to a wire.
BG
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Soryn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 31
30일 전: 129
전체 시간: 13,931
