주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VG248QE는 2013년 1월 Asus에서 출시한 24인치 게이밍 모니터입니다. 144 Hz 주사율로 작동하며 Nvidia 3D Vision을 지원합니다.
Why it's not turning on?
When I plug it to the AC the power LED (blue) turns on but the screen won’t show anything. The screen leds are not even turning on so I suppose it has power related shortcut.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Inside the monitor there is a power supply board, a logic board (motherboard) and the led panel of course. How many possibilities are there that the led panel is fried? I'm asking this because it would't be such a problem if I have to replace the boards, they are quite cheap, despite the led panel.
의
댓글 달기
답변 2개
가장 유용한 답변
@chaingunjoe
this series had an issue with the power board. Disassemble it and take a look at the board for leaking, domed capcitors. Postsome images of your boars with your question so that we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Try to connect to any other display device by using same hdmi cable if that too having the same issue change the cable and try again if this doesnt work for both the displays there must be a issue.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Unfortunatelly when I press the Turn On button the monitor doesn't show anything, not even the lack of signal text. I'm starting to think it's a motherboard related issue.
의
Are you able to connect to external display and do you receive any signal in external display
의
댓글 달기
답변을 추가하세요
cerruti.enrico 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 2,706
