주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 노트북은 15.6인치 스크린 디스플레이, 500GB 하드 드라이브 및 Intel Core i3 프로세서를 탑재하고 있습니다. 2012년 2월에 출시되었으며 모델 번호 NP300E5A-A02UB로 식별됩니다.
Headphones/ laptop Jack socket problem
Hello i’m new here i got a problem with my laptop jack socket for headphones. When i plug my headphones in only left one is playing, but when i lightly push the plug down then both works just perfectly, my guess is that somethings wrong with jack socket, maybe some contact is slightly bent or something, any idea if i can bend it back i i have to search for new jack socket? i tried looking inside but its hard to see which one is the one odd.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
You’re sure it’s the laptop socket that’s faulty, and not the headphone plug, I presume. With a magnifying glass and the light shining into the socket as best as you can get it, you may be able to see something. There’s a small chance that you can bend a contact using a pin, but you are quite likely to make it worse. The left channel is the tip of the jack plug and the right (giving trouble) is the next ring on the plug. The troublesome contact will therefore be around a quarter of an inch from the bottom of the socket, i.e. half way down.
Most laptops are fairly straightforward to take apart and this seems to be no exception (https://www.youtube.com/watch?v=WrMbmV2d...). From the video, I can’t see where the headphone socket is but replacing it shouldn’t require more than average soldering skills. You just need to make sure the replacement has the pins and fixing tags in the same places. You might be able to get a spare for your specific laptop on eBay.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Yea i checked headphones on different computer and on phone and they work great, and left one works with laptop only after pushing it slighly down. On ebay i hadn't found any seller with this model of jack who imports to Poland.
댓글 달기
DEVICE NAME-dell inspiron 153000
in my laptop headphone jack is not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jacek Kaszycki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 28
전체 시간: 388
