주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년에 출시된 보급형 Photosmart 프린터입니다. 일회용 프린트헤드가 장착된 HP 3색 잉크 카트리지를 사용합니다.
Scan Failure on second attempt.
I can print one copy after I turn the printer on. A second attemp will give me a “Scan Failure”. I restart the printer and the same thing happens. If I try to Scan, I get the overview ok but The scan failure comes up if I try to scan. I looks like the scanner is not returning to the idle position after a first scan.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
It sounds like your reading head for your scanner is not returning to it’s “home” position. If you are halfway not fumble-fingered like me, you can gin entry by usually removing the top glass. You should be able to get the head into it’s '‘home” position and check the cogged belt that moves it to determine if the belt just jumped a notch or if you have worn belt or stepper-motor problems. Check for a mark on the belt made by a marker at the factory when your unit was first set up. This will help you determine what’s going on. If it checks out mechanically, try reloading your driver software for the HP. And be careful around any of the printer’s so-called “secure” home pages for software downloading—-they seem to be a heavily targeted area for con artists with their own software and programs.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jnmstuff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 12
전체 시간: 299
