주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Keurig K55는 모델 번호인 K55 Classic Series를 통해 식별할 수 있습니다. 2015년 12월 2일에 출시된 K55는 K 컵과 일반 커피 가루를 모두 지원합니다.
No power into machine
I recently bought a Keurig K55 from bed baths and beyond. I was falsely sold this item by the sales rep. I asked if the machine would work in the uk and I was told to put a 3 pin adapter on the end of the plug and it would be fine. I done exactly this it started hearing the water and then suddenly stopped. Can I be told how to fix this and if I should use a voltage dropper convertor?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @veepatel
Confirm the input voltage on your Keurig K55
there should be a label mentioning about input voltage, e.g. 110V
In UK, voltage is supplied at 230V....
If your device is labelled at 110V and you connect it to 230V, likely is could be damaged.
I think you mean step down voltage transformer (drop voltage from 230V to 110V), you need to consider on your coffee maker power consumption also. Not all converter might be suitable of this.
update us first on your current machine voltage input.
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
I'm guessing I have damaged it. Yes the voltage is 110v. Is there anyway of repairing it?
의
Hi @veepatel
Well you may try opening up and check, hopefully would be just the power supply section is damaged.
take and share some pics with us
의
Sure will do when I get home from work. Thanks for ur help
의
Hi please find a picture below.
의
Does anyone which power supply I have to buy as in model number etc...
Thanks
의
댓글 달기
이미지
here is the picture
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vishal Patel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 14
전체 시간: 1,130
