주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
new screens "Searching" indefinitely. (Old Screen Works)
hi there!
we have an SE run through our store, and well, the titel says it all.
we tried 4 new screens, and they all had an indefinite searching issue.
we put the old screen on, and it instantly connected to the network.
i have uses the “Airplane mode off/on” from the old iphone 4/4s. this does not rectify the situation
im curious if apple has made another forced obselence update?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
i have had it happen on other models but turning aeroplane mode on and off solved that problem
yeah, that used to be a thing for the iphone 4/4s. unfortunately this doesnt fix the issue for this. thankyou for the update though. ill add that to the list of things tried
Intereresting because the antenna is not in the screen, rather in the logic board. I would have said it would be the antenna but you replaced the screen, not the Logic Board.
i know. this is why it is weird. if i put the old screen on, and it didnt work, i would have been able to chalk that up to technician error.
But unfortunately, (and forutitously at the same time) it works fine with the old screen. this is what confuses me.
댓글 달기
답변 1개
선택된 답변
The iPhone 5 had a similar issue. It was only solved when you do a reset through dfu. After doing so it would give a no sim error. After removing and reinserting the sim it would work normally. I’m not quite sure if you would want to try this with the SE. but it is a major headache. Sometimes apple gets on my nerves.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i did hundreds of iphone 5s, and i never encountered this. thats likely why i didnt think to try it. ill email my customer and suggest giving it a shot. thanks for your help
댓글 달기
귀하의 답변을 추가하세요
Scott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 101
