주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell VRC-100R은 모델 번호 536-BBBS로 식별할 수 있습니다. 2017년 10월에 출시된 1세대 블루투스 가상 현실 컨트롤러입니다.
Fixing the trigger on the WMR Controller?
The trigger on my right controller is stuck “pushing in” when I am in VR. I have tried to disasemble the controller to see if there is anything wrong with it, looks like it’s missing something. What could it be missing? I don’t want to disassemble my left controller needlessly to see if it’s missing something.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Ok…well apparently ifixit thinks my answer is spam. I’ll try one last time:
I think I may have the same issue, and I fixed it. I followed the ifixit guide for doing a touchpad replacement (apparently if I link to that tutorial, this post gets marked as spam, so you’ll have to find it yourself), through step 7, removing the back panel, which contains the trigger. In my case, the small metal rod that holds the trigger in place and allows it to rotate had slipped out of the hole on one side. I wiggled it back in place, and after putting everything back together it worked. It looks like this rod could easily slip out of place. Not sure if this is the same issue for you, but I hope it’s helpful. Best of luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
NO PE 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 1,110
