주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tecno Y3s Android 스마트폰은 2015년 4월 Tecno에서 출시되었습니다.
phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 20
댓글 2개
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
의 공유
Sir, my mobile battery is very weak, what should I do to get it fixed?
의 공유
댓글 달기
답변 7개
가장 유용한 답변
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
이 답변이 도움이 되었나요?
점수 3
댓글 달기
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
이 답변이 도움이 되었나요?
점수 3
댓글 달기
To take a look on battery terminal if a well connected second to check life of battery
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
의 공유
댓글 달기
Phone is not power on and showing logo
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
의 공유
댓글 달기
My phone charging socket is not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
No problem my phone is ok
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Charging my phone slow way
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Eric Matibila 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 40
전체 시간: 3,654
