주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Stealth Pro는 MSI에서 제조한 게이밍 노트북입니다. GS63VR 6RF는 2016년에 출시된 15.6형 모델입니다.
How do I replace the Fans for CPU and GPU?
Cpu fan is dead/broken, and needs to be replaced, but I can’t see how to, without disassembling the whole thing, heatpipes and all.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Watch this video.
The procedure for replacing the SSD, RAM and CPU/GPU fans is essentially the same - disconnect the motherboard and flip it over. Once you have flipped the motherboard over, there are some small screws holding the fans to the heatpipes. Disconnect those and the wire connections to the motherboard and you will be able to remove the fans.
A few gotchas:
(1) Pay attention to how the wires are routed from the fan to the motherboard. I inadvertently crushed one of the wires while screwing the motherboard back in on reassembly.
(2) Make sure the fan wire connectors to the motherboard are firmly snapped into place.
(3) Reconnect the wire for the left speaker back into the motherboard before making any other attachments or replacing any screws. There is a small piece of plastic on the housing that will prevent you from reconnecting this wire once the motherboard is in place.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
David 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 44
전체 시간: 1,030
