My phone drop in water
how do i fix my phone if it drop in the water?
좋은 질문 입니까?
The first step is to not try to restart/sync the phone. This may further damage your phone. Remove your battery asap The next thing to do is to clean it. Disassemble your phone using this guide Xiaomi Redmi Note 4X LCD Screen Replacement . You must remove all the EMI shields of the logic board. If you do not remove those you are not cleaning your board properly. Clean everything with +90% (no less than 90%) isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone, all the points are still pertinent to your phone. Pay particular attention to the SMD components, check for charred, missing or broken components. You can then dry the board in an oven or equivalent at 220deg F (not higher;-) for a few hours. Best way to clean it would of course be through an ultrasonic cleaner. Consider professional help with that When it is properly cleaned, replace the battery. Replacing the battery is a must since any immersed battery will eventually fail (sooner than later). Only after all this can you diagnose what is really going on with your phone. You cannot properly diagnose your phone until you got that issue resolved.
안내서
난이도:
어려움
1 - 2 hours
안내서
난이도:
운영
2 - 3 hours
해당 답변은 도움이 되었습니까?
@kennn You will need to take your phone apart and use <90% isopropyl alcohol to clean every square inch of your phone’s internals. If there is corrosion on the Motherboard I guarantee you that your phone has gone to phone heaven.
Here is a guide on how to take off the screen so that you can access the internals.
@justbelikebrett Drying out electronics with rice is a wives tale, you have to boil rice in order to absorb any water at all.
해당 답변은 도움이 되었습니까?
@justbelikebrett I literally said in the answer that the guide was to be an assistance to get the phone screen off so the OP can clean out their phone and check for corrosion, and why did you bring up the phone battery?
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 305
댓글 1개
all the buttons didn't work
Kenn 의
