주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
개선된 1세대 Ranger 소형 픽업트럭을 위한 수리 안내서 및 지원 정보. Ranger는 1989년식 모델부터 페이스리프트와 몇 가지 기계적 업데이트를 거쳤습니다.
4 years without being started
Just replaced the fuel pump ,battery and emptied the gas tank put new gas but it still wont turn over , spark plugs are good as well as the coils and along with the spark plug wires& new relay . The fuses are good .has an after market alram system that no longer works with the clicker batteries were replaced .any one whos dealt with this kind of problem id appericate some help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Phillip Griego let us know what works. Do the lights come on? Do you have any sign of life on your Ford?
의 공유
You said it wouldn't turn over. Do you mean there is no "cranking" when you turn the key, or that there IS cranking, but it does not start?
의 공유
댓글 달기
답변 1개
You may need to pull the plugs and carefully hand crank the engine to break the vacuum seals and varnish buildup on the cylinder walls & pistons. When you store a engine for over 3 months you really need to add in an additive to the gas and fully fill the tank and you need to put oil into the cylinders to coat the walls (doesn’t take much).
Edmunds - How to Prep Your Car for Long Term Storage
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Phillip Griego 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 332
