주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Insignia Flex 8은 Tianshi Digi-Lando에서 제작한 다목적 태블릿으로, 인터넷 연결, 사진 촬영 및 앱 사용이 가능합니다.
I Forgot my log on pattern
How do you recover your logon pattern? I forgot mine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
insignia tablet forget pattern
의
댓글 달기
답변 1개
가장 유용한 답변
Sadly you will have to factory reset your tablet in order to be able to use this tablet again. Factory resetting your tablet will erase all data stored on your tablet.
Ensure the tablet is connected to the charger and has at least 45% battery left. If the battery dies during this process the device could be damaged.
  1. Power off the tablet fully.
  2. Press and HOLD the Volume + button.
  3. While still holding the Volume + button, press the Power button until the screen illuminates and shows Insignia.  Then release the power button only
  4. Continue holding Volume+ until one of two screens appears
  5.   A) -A screen appears with only an Android mascot in the background. If this happens simply let go of volume + and press it one time.  You should then see the screen shown in item 'B'
         B) - A list of options in the top left of the tablet screen.
Six - Use Volume - to select "wipe data / Factory reset" and press the power button to select it
Seven - Use Volume - to select "Yes -- delete all user data" and press the power button to select it.
Eight - Following the reset, the device should boot up and go through the initial setup process again as when it just came out of the box.
Feel free to ask questions!
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
My laptop reset list is in Chinese which one is the factory wipe/reset
의
this won’t work for me
의
My screen doesn't look like that it all blue with different options and it says I don't have enough space to reset my laptop
의
What do I do if it says there is not enough space to reset the laptop but I can't log in to make space?
의
How do I reset a pin?
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Cindy Snodgrass 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 8,598
