주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 8월에 출시된 Xiaomi Air 12는 실버와 골드 색상으로 제공되며 모델 번호 161201로 식별할 수 있습니다.
Replacing the LCD screen or cable
Any chance you could go further and explain how someone would change the LCD cable. Mine appears to be broken as the screen won't light up at all but computer can still output to HDMI.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hello, my left hinge is broken. Do you know how to fix this and where to buy it?
Greetings from Germany
Hallo Manuel, konntest du das Problem lösen? Das Display Scharnier ist bei meinem Xiaomi Air 12 auch kaputt gegangen...
댓글 달기
답변 4개
가장 유용한 답변
I replaced the screen of my Xiaomi air 12. You have to disconnect the power cable, and 3 connector coming from the screen (camera, antenna (gray and black), and monitor cable ) . Unfortunately the screen is glued to the lid, so you have to heat up the glue first and then gently lift it with a suction cup. The new screen has to be glued again on the lid. On the bottom part of the monitor there is also a plastic strip that has to be glued on the monitor before you connect the cables and glue the monitor on the lid. I hope it helps.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
This is the answer I wanted a month ago. Did the exact thing you did but didn't warn the screen up enough and it chipped in the corner.
Hi Mauro, would you be able to go into a little more detail about how you removed the screen? Where is the glue? Is it on the metal on the back of the screen or on the glass border? Did you heat the front or the back? When removing the screen should I attempt to lift only the glass or does the black plastic surround also come out of the lid? Thanks, Peter.
Thanks, this is very helpful. I believe there might be a dfiferent model out there because others have instructed on just sliding the screen. One thing I noticed in my attempt is that the lid magnets got stuck to the screen, while the plastic strip actually remained connected to the lid.
Sliding the screen or heating up removing adhesive. Two different repair methods . There are usually at least two methods of replacing LCD screens depending on how much of the assembly you are or aren’t buying/ looking to replace. With the LCD alone or full screen housing/ frame removal method. It’s common for more ways than one on any device or laptop.
댓글 달기
You can replace the cable with this one from AliExpress. Unfortunately there isn’t currently a guide that shows how to replace this, so you are kind-of on your own.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
actually you don’t need to heat up the screen to remove it, it’s a slider snapfit, you need to remove the hinge cover and then remove 2 little screws and then slide the screen downwards
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
Ciao dovrei cambiare la cover posteriore del mi air 12.5 sapresti darmi delle dritte?
Thanks but could you give a little more details or, better, a photo of the slider and screws ? I have to replace the connector on my daughter's Xiaomi air 12 and I can't find these items ...
Thanks again
I didnt find the two screws on the screen. Can you, Lorenzo, show a photo of the procedure or at least a photo of the screws?
Thanks.
well, I found a youtube video with all the process: https://www.youtube.com/watch?v=TIlcwruC...
댓글 달기
Hi, I found a great youtube video with the proceess: https://www.youtube.com/watch?v=TIlcwruC...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Richard Leckie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 33
전체 시간: 2,233
