주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년 1월에 출시된 10.1인치 디스플레이와 2.7파운드 무게의 HP 넷북입니다. 블랙, 레드, 블루, 실버 색상으로 제공되며 6셀 배터리가 장착되어 있습니다.
Turns on but screen doesn't
My hp mini 210 turn on but screen is blank
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 7개
Can you give us some more details about what you might have done to your device to cause it do this?
Hi @magicjet_
Any beeps or pattern LED flashing?
when you power on the computer, observe on the HDD LED if there is any activity.
when you hook to an external display.... do you get display?
you might need to invoke some key to project out to the external display.
else
another test you can do is to test with another known working RAM first
HP Mini 210 RAM 교체
I have done all of those things.
Hi @magicjet_ ,
Do you get a display showing on an external monitor connected to your laptop via the vga port, when you press the F4 key, when the laptop has been turned on and presumably booted into Windows?
No It doesn't do anything
댓글 2개 더보기
댓글 달기
답변 2개
선택된 해법
I think these had a common problem with the ribbon that connects the screen in the top half to the motherboard in the bottom half… if I'm thinking about the same netbook u needed to replace the ribbon to get it to work properly or fiddle with it and squeeze it etc to get it to work temporarily
Basically try replacing the ribbon it's quite a fiddly job though
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Can you give me a link to where I can buy one?
댓글 달기
Test ram in my experience when ram is not functioning well it will turn on without screen .
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 11
전체 시간: 1,750
