주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero5 Black는 2016년 10월 GoPro에서 출시한 HD 방수 액션 카메라입니다. 4k 해상도의 이 비디오 카메라는 음성 제어, 터치 스크린 디스플레이, 내장 와이파이 기능을 갖추고 있습니다.
Sd card isnt recognized
Sd card got stuck in slot and had t be pried out. It now goes In Crooked and isnt recognize. what can be done to repair?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
I would try opening up the camera and looking at the SD card port on the Motherboard to see if anything is broken.
GoPro Hero5 Black 마더보드 교체
If something appears to be broken you can replace the Motherboard with a replacement from iFixit too.
GoPro Hero5 Black Motherboard
This part is the motherboard for the GoPro Hero5 Black action camera. 이미지
제품
$24.99
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
So the port is coered obviously by the battery case so hard to see if anyt b ings broken. It does slide in crooked so I asume sometjings crooked or twisted. The mother board has the sd card slot attached so its 1 piece ? Thanks
의
@zchef Yeah, you will probably want to replace the Motherboard as the SD card slot is soldered to it. That’s probably your best option.
의
댓글 달기
it is not soldered
it has legs to snap into place
no one sells just the sd card holder,just the motherboard,i looked
but did i overlook one
here is take apart video
https://www.youtube.com/watch?v=Xq3c90Am...
the sucker is glued in places and epoxy applied at lens
once removed front cover is distorted due to heat making some part malleable
because the lens area with epoxy is removed by pulling leaving a rugged rock hard
all terrain surface
it cannot be removed
the rest is screws with torque screwdriver
follow take apart video and pay attention to removing the battery holder
now you will see motherboard and sd card holder to remove mother board and you’ll see
use philips 0 screwdriver to remove mother board
check underside of motherboard for sd card colder mounts
1.you will need to purchase a new front cover that will fit, but not flush due to epoxy residue,
camera is no longer waterproof
when taking apart some screws just spin.had to cut off with dremel and once the board has been removed,pulled the screw fragment out with needle nose plyers
now you don’t have enough screws
but say you bought the overpriced motherboard
the screws are self tapping and others a nuisance
easier to take out
the material the screws are composed of is just sligthly wobbly magnetic
cannot be fully magnetized, say from a discard microwave magnet or buy online
resulting in screw holding lightly to screwdriver,apply even the tiniest pressure the screw falls off.
  1. now you know you should of never attempted to do a self repair
# you can sell off parts
  1. or you should of sold off camera as is saying sd not going in straight and have some other diy take it off you hands
  2. take the hit and but another camera with your parts proceeds or the diy guys money
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kerry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 842
