주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Error 6 while rewriting firmware
Dear users,
I’m tasked with saving an iPhone SE that’s currently bricked. During boot it will sit on the Apple logo screen and subsequently enter recovery mode on its own.
The simple answer would be to flash iOS 12 (it’s currently also running this but trying 11.4.1 yields the same results) back onto the device but during the flashing process iTunes will throw error 6. This happens right as the phone reboots, enters recovery mode, and subsequently shows the first progress bar. The progress bar will not fill even a tiny bit. The same result has been replicated on 3 machines so far.
I’ve also tried a third party flash tool (3u Tools) but it gives me the same problem. It won’t get past the “Updating S3E Firmware” stage.
In the iTunes log files I’m finding “Failed to update NAND firmware”, which leads me to believe the flash chip might be bad. After reflowing (I don’t have the tools at hand for a reball sadly) the chip I’m still getting the same issue.
Am I missing something or is it safe to assume the phone is dead?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I have the same problem with my Iphone 6S. Does anyone know how to fix it? I only had it for 2 months and it sucks
댓글 달기
답변 1개
선택된 답변
The NAND has underfill so it’s not a good idea to try reflowing it; you can actually cause shorts or solder blowouts. If you have access to the schematics (easy to find with Google - sorry, can’t share them here), then I would check the voltage lines that power the NAND to see if there is anything wrong.
Do you know what caused the phone to brick in the first place; was it due to physical damage, repair attempts, water or just out of the blue?
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
My problem is when i flash the firmware to i phone se and it is done . i see the error while the apple logo is appear and stop in half of firmware extrecting line is stopping . So can anybody help me please? ....
댓글 달기
귀하의 답변을 추가하세요
Marnick Visser 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 3,634
