주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 PlayStation Vita인 PCH-2000 시리즈는 일반적으로 PS Vita Slim 또는 PS Vita 2000으로 불립니다. 2013년 가을 일본에서 발표되었고, 2014년 5월 북미에서 출시되었습니다. 이 기기는 휴대용 엔터테인먼트 기기로 분류됩니다. Wi-Fi, PlayStation Now, PlayStation Network/Plus, Bluetooth를 지원합니다. 모델 번호: PCH-2001.
PSV - charging issue - troubleshooting ideas
Hello,
I recently bought psv slim on ebay. Visual everything looks fine and in good state.
Issue is that battery is almost empty and if you plug usb to charge (from electricity outlet with phone charger, laptop usb or power bank (already tried different usb cabels)) it’s not charging at all while psv itself on.
If you turn off the psv then it charges for about 10 minutes (always the same time) and then you can use console for some time. If you try charge longer, orange light do not show up. If you unplug and plug again the usb it shows for about 50sec and turn off (the orange light). And it’s always the same time. Old owner told me that he tried to replace batteries, but I am thinking to do this also.
I dissembled unit and find nothing unusual inside, everything looks in tact without any trash or visual damage.
PSV version is 3.65
It’s really strange that charging time is the same every time.
I tried to reset factory settings and also unplugged the battery for some time to perform physical reset.
Charger port itself looks intact and in good state on outside and motherboard side (visually) .
Maybe some overheating or voltage security measures stops charge?
Could any one suggest what else I can try to fix this?
Thank you very much :)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개:
I also tried an official charger.
Same, you can see orange light for some time and it disappears. I am not sure if a battery charging at all. Maybe something wrong with the motherboard itself?
Would be interesting to check resistors with a multimeter, but I have no idea what discrepancies should look like. Also, just in case I cleaned motherboard. Any other ideas what to check?
댓글 달기
답변 2개
cut it off and cut it back on
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi, what do you mean? To cut it off the micro usb charging port? Or unplug the battery?
댓글 달기
Hello, are you able to measure 5V on board behind the power connector?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Aivaras 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 3,369
