Samsung galaxy tab 4 Tablet reboots every 15 minutes?
After not using my tablet for about 6 weeks I struggled to get it to charge. After buying an original samsung charger its all sorted but not the tablet reboots every 15 minutes.
Following other suggestions I cleared the cache in asr mode, and have also done a full wipe in asr mode. Now it loads up connects to the wifi and then reboots every 15 minutes or so.
Any ideas? TIA ☺
좋은 질문 입니까?
I am assuming that what you mean by a “full wipe in asr mode” is that you have tried to do a factory/hard reset?
https://www.technipages.com/galaxy-tab-4...
[deleted] 의
Hi, Yes. Full factory reset by turning tablet off. Holding power, volume up and main button down until android symbol appears and then rebooting.
Nichola 의
Sounds like a chip fault, changing the battery might help but it sounds like it’s on it’s way out.
Daniel 의
Hi,
Does it do this with the charger connected and switched on?
jayeff 의
Not tried that but will do that now and get back. Thanks!
Nichola 의
댓글 8개 더보기
