주요 콘텐츠로 건너뛰기
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 질문 전체 보기
Samsung galaxy tab 4 Tablet reboots every 15 minutes?
After not using my tablet for about 6 weeks I struggled to get it to charge. After buying an original samsung charger its all sorted but not the tablet reboots every 15 minutes.
Following other suggestions I cleared the cache in asr mode, and have also done a full wipe in asr mode. Now it loads up connects to the wifi and then reboots every 15 minutes or so.
Any ideas? TIA ☺
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 13개:
I am assuming that what you mean by a “full wipe in asr mode” is that you have tried to do a factory/hard reset?
https://www.technipages.com/galaxy-tab-4...
Hi, Yes. Full factory reset by turning tablet off. Holding power, volume up and main button down until android symbol appears and then rebooting.
Sounds like a chip fault, changing the battery might help but it sounds like it’s on it’s way out.
Hi,
Does it do this with the charger connected and switched on?
Not tried that but will do that now and get back. Thanks!
댓글 8개 더보기
댓글 달기
답변 1개
Since i had many tabs that response badly when battery needs to be replaced i would try that first. Otherwise iT can be a heating problem. But my guess is changing the battery Will work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nichola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 157
