주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Why does my iPhone shut down (as in run out of battery) after 5 minute
Lately I have been getting a multitude of problems which includes:
Unresponsive screens
IPhone Dying after 5 minutes of being idle (much less battery life if in use - Has to be connected to a source of Power to function on a basic level)
Randomly types unwanted letters at random times
Heats up extremely easily
etc…
I would like some help for at least one, if not all, of this is possible.
Thank’s for your time
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Do you use a Mac Or PC with ti?
댓글 달기
답변 1개
선택된 답변
Your battery is most likely at the end of its life. To be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). Anything less than 70% of design capacity will require replacement.
 Based on your description, you may also have a screen issue. However, I would start by replacing the battery first and see if that solves the shutdown issue. Then if that is solved but you still have Touch issues, then you’ll want to consider changing the screen.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Yoake 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 45
