주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 10월 일본, 2015년 9월 북미에 출시된 Nintendo의 첫 번째 주요 3DS 모델 변경 버전입니다. 2015년형 3DS는 개선된 3D 성능, C-스틱, 새로운 내부 amiibo 지원, 새로운 트리거 버튼 세트를 도입했습니다.
Where is the WiFi chip?
New 3ds screen is black, need help finding the WiFi chip on the inside of the console. Very differnt then other 3ds and new 3ds xl. (Not the same)
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
Everywhere I looked people said that the WiFi chip disconecting from inside the 3ds was the problem as to why the screens went black. If there’s another solution it would be much appreciated but I don’t know what else to try.
의
I haven't heard that, but that's interesting. Definitely give it a try and let me know if that works. I have seen where one of the ribbon cables being loose will cause the device to not power on or properly display to the top screen. While you're inside, I'd be sure to check all the ribbon cables. Let us know how it goes.
의
@griffin Reed same issue for me
의
댓글 달기
답변 1개
가장 유용한 답변
Hey, Griffin. The Wi-Fi card is located inside the top screen assembly. Follow that little blue wire that connects to your main board. Go to 25:11 of the video your photo seems to have come from and you’ll see it in the upper left hand corner.
https://www.youtube.com/watch?v=dLLK7uhd...
Why do you need to access to your Wi-Fi card for a blank screen by the way?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
griffin Reed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 18
지난 30일: 72
전체 시간: 5,289
