주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Patagonia 아우터는 쌀쌀한 날에는 몸을 따뜻하게 해 주고 축축한 날에는 젖지 않게 해줍니다. 수리 난이도는 간단한 꿰매기부터 복잡한 칸막이 수리까지 다양합니다.
Old rain jacket delamination
Hi,
I have an older (6 years?) rain jacket that is starting to delaminate. The seams are still sealed, but the white, water repellent coating on the inside of the jacket is starting to peel off the outer. Do you have any suggestions to combat this?
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개
I have the same issue. Bought mine about 5 years ago, only worn in the rain, and never washed or dried it. The inner white coating is completely gone around the waist up about 3 inches and the same on the sleeves. It flakes like dandruff and is no longer waterproof in those areas, any solution from Patagonia?
의
Hi @sammeybobbles, have you tried to reapply the repellant? If you scroll down a little bit an answer from Mayer has a guide on how to do it. I'm attaching the link here just in case you aren't able to find it.
Hope this helps!
내구 발수(DWR) 코팅 재도포 방법
의
댓글 달기
답변 3개
가장 유용한 답변
See if this guide helps solve your problem:
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I’ve had luck reapplying a waterproof coating several times over the life of the jacket. Unfortunately, this problem is on the inside of the jacket and the actual lining is coming off.
의
댓글 달기
I have the same issue, so i called the store if they can repair it and they said that it ‘s not repairable…But they can replace it for freeeeee! brand new jacket,it might not be the same style but, hey! its brand new Patagonia. Hope this helped you.
cheers!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Unfortunately, this problem happens constantly if it is not washed properly or very few and when it starts to happen it is inevitable, it is just ready to be recycled (I would recommend washing it at least every month if you are using it daily) and sometimes reactivate the impregnation. The next time you buy one, keep it in mind and you will be able to have it for many more years, you also have to consider how much weight and wear you gave it, sometimes you have to invest in one that has more layers (now Patagonia is doing most with three layers at a good price). I hope it helps you a little. Greetings from Berlin
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Isaac Williams 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 95
전체 시간: 11,554
