주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G602(무선 게이밍 마우스)에 대한 배경 정보입니다.
Mouse wheel is not scrolling
I have a problem with my mouse scroll wheel. The scroll is not working at all but the wheel clicks just fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I have recently started having this problem. I was sold it as brand new. It was working and it just stopped scrolling. Middle button works, but no scroll. There's no dirt or anything.
의 공유
댓글 달기
답변 6개
가장 유용한 답변
Logitech G602 스크롤 휠 교체
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
@ramirocampa Thanks for your help. The problem is not in the mechanical side of the scroll. When I scroll the wheel, it rotates well. The issues is that rotation doesn't get captured or sent to the computer i.e. no action happens
의 공유
it might be a problem between the wheel and the digitizer. usually back in time there was a digitizer usually near the axis of the wheel. i dont know if it is suitable in your case but you might take a look at the "gears" or anytype of physical damage between the axis of the wheel and the support of it. in other mouses may be a worn out plastic axis... instead of being square shaped or any desired form it may be damaged (like too roundy) i hope this helps.
Regards
의 공유
댓글 달기
I had the same issue. Took it apart, and found the wheel clogged up with cat hair. Cleaned that up and it’s working again. Thanks for the pics on how to get it apart though :)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
scroll wheel was intermittent. Opened as above, removed ball of lint with tweezers from wheel area. Immediately worked correctly. Spudgers not necessary for this repair. Fingernail worked great.
PERFECT answer for my variety of this problem!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
First i was thinking it doesn't work because of software. I uninstalled everything, but it didn't help .
Thank you. was dirty inside. fixed
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Open it up (look for a yt tutorial if in doubt) and take it from there
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well I will suggest you to check out the following: https://www.systweak.com/blogs/logitech-...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
eng_m_hamda 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 72
전체 시간: 8,355
