주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9세대 Honda 소형차입니다.
Multiple simultaneous error messages
2015 Honda Civic; LX, 1.8L V-Tec SOHC 16V; Manual Tran — Check TPMS, Check Power Steering, Check Emission System, Check Hill Start Assist, Check (VMS?) - all came on at once when starting yesterday. Tires are fine, P/S is fine, the vehicle runs and drives normally (I’ve had it for three years). I suspect a fuse, module, or connection.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hey, Rick. Check your battery voltage. I’ve seen low battery voltage trick these cars into limp mode and/or set many different codes at once. If your battery voltage is fine, post a list of exactly which codes were present (ex: P0300) and I’ll see if I can find anything. I agree with your suspicion that it’s a connection or some module on the CAN-Bus.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
So, I popped the hood to do some troubleshooting yesterday (Monday), poked around under the fuse box cover and wiggled a couple cables. Before I even attempted to check the battery voltage I started the car, and lo and behold, the error messages disappeared from the LCD display! I can't actually say whether just poking around fixed it, or it fixed itself by sitting quietly in the driveway from Saturday evening to Monday afternoon, but it strengthened my theory that it was a bad connection somewhere. Tuesday afternoon I drove the car to work (~22 miles, mostly rural) with no further issue. Thank you for your consideration.
의 공유
댓글 달기
답변을 추가하세요
Rick Wood 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 37
전체 시간: 2,186
