주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델명 A1369, 1.6, 1.7, 1.8 GHz CPU, 64, 128, 256GB SSD
Why is my Mac screen doing this?
Having some issues with a grey vertical line intermittently on the screen. When I touch around the actual screen it seems to make the problem occur more. When I leave it upright and open on a flat surface sometimes it will go away.
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Sadly you banged your systems lid or stat something heavy on it damaging the LCD panels connections to the ribbon cable. We call this failure a TAB error. When the fragile vaporized metal on the LCD glass has pulled away breaking the connections.
To fix this you’ll need to replace the display assembly following this guide: MacBook Air 13" Mid 2011 디스플레이 어셈블리 교체 and here’s the needed part: MacBook Air 13" (Late 2010-Mid 2011) Display Assembly
Replace a display compatible with the model A1369 Late 2010 to Mid 2011 13" MacBook Air laptop. Part #661-5732, 661-6056. Features a 1440 x 900 13.3" LCD screen. 이미지
제품
$399.99
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Ouch! That's gonna be expensive...
As a cheaper alternative can I just replace the LCD panel instead of the entire display?
Sorry, it's not really cheaper ;-{
The problem is you'll need to replace quite a few pieces as you'll damage them in the process.
You'll also need quite a few tools and even afterwards it won't be as neat as the edges will be nicked up and you'll likely have some damaged backlight sheets.
To give you an idea how messy this can be take a look at this guide: MacBook Pro Retina 디스플레이 분해도
I'll do the older MacBook Unibody LCD's, I won't do the Air's or the newer Retina's.
댓글 달기
답변을 추가하세요
Matthew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 425
