주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
swiping up from bottom does not work on the ipad 2 front panel.
I replaced my ipad 2 front panel. everything is working except when i try to swipe up from the bottom It does not respond. I can swipe up in the middle and upper part of the ipad. but i cannot swipe upward from the very bottom of the screen. I also did not seal the ipad securely so it is partially sealed and partially not sealed towards the bottom and the left side. Could that be the problem? If not what could be the cause of the issue. I bought the screen off of ebay.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
3 댓글
Why did you replace your original front panel? Was it broken? If it’s not broken, try reinstalling the original front panel and see if this continues.
It was severely cracked to the point where it would not respond to touch.
@kgreaves Alright, I suggest you take a look at Minho's answer as it answered this question well.
댓글 달기
답변 1개
선택된 해법
First of all, kudos for properly testing the screen before sealing it up. It’s a critically important step that many folks ignore.
It’s not uncommon to have bad digitizers, especially if you bought one off of eBay. The first thing to do is to verify that the digi is properly connected and that the connector isn’t damaged in any way. Those ZIF connectors with the flap have to close uniformly otherwise some of the connections from the flex will not make proper contact and therefore you will see a “dead zone”.
If that looks good, then you probably have a bad digitizer. Have your vendor replace it or order one from a reputable vendor like iFixit.
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
귀하의 답변을 추가하세요
Kevin Greaves 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 106
