주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon AE-1은 교체형 렌즈를 사용하는 35mm 일안 반사식(SLR) 필름 카메라입니다.
How to replace Battery contacts?
Hi!
I bought an old A1. It doesn‘t fire. I think it´s because the battery contacts corroded. I already tried to clean it with alcohol but no chance. Is there a possibility to get to the battery contacts. Maybe to replace them or to remove it and put it into alcohol overnight.
Greetings
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Alcohol is not what I would use as it won’t cut through the battery corrosion. What you need is white vinegar use a cotton swab (Q-Tip) dipped in the vinegar and hold it against the contacts. You also need to flush the vinegar with water using the same approach using a wet cotton swab.
The bottom contact has a spring to push it up to make contact to the battery if this is not working you’ll need to replace the battery holder. Its a bit of work! Its not something I would recommend for a first timer as its a delicate job. Here’s the Canon A-1 service manual jump down to the exploded views at the end there you’ll see whats involved to get to it. You basically need to take the whole camera apart.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lucas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 35
전체 시간: 2,891
