주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS Rebel T5는 2014년 2월에 출시된 1800만 화소 DSLR 카메라입니다. EOS 1200D 및 EOS Kiss X70으로도 알려져 있습니다.
Flashing Yellow light in front of camera
Yellow light flashing on front of camera and will not let me take a picture. Pop-up flash kept hitting hat brim and eventually stopped working. This is for my EOS Rebel T5 1200D
I have removed the battery and that did not solve the problem.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
I know that you probably aen’’t having this problem anymore but I also had it and figured out that I had accidentally turned on the timer on my Rebel t6. The yellow light should blink for about ten seconds before taking a picture. To turn this off (on the t6) click on the left button next to the set button and then select “single shooting”. I hope that helps!
이 답변이 도움이 되었나요?
점수 5
댓글 5개:
Thank you so much !! It helped me
의
It helped me too, thanks buddy
의
Thank you! That totally fixed it. God bless you!
의
Posted photos on my answer to confirm this, checked on a T6i.
Essentially the T6i is the full fat version of your T6.
의
I made an account so fast and even screwed up my name just to say thank you for this. I've been photographing all my life and a rookie mistake almost sent me into a spiral because I'm in a rush
의
댓글 달기
What does it do when you try to take a picture? Specifically, at what point does it stop? Does the lens autofocus (if you have an autofocus lens for it)? Do any of the viewfinder lights come on? And what shooting mode are you in?
The flash thing is weird. It shouldn’t have stopped working just from hitting the brim of your hat. Have you tried turning flash off and making sure it’s not set to auto flash?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이미지
이미지
이미지
It's the self timer mode.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Neil Fox 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 77
전체 시간: 8,883
