주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86 또는 2.13 GHz Core 2 Duo 프로세서
Can't boost from SSD128
After a crash, can't boost with SSD purchased from you. After the boost chime, the screen is blank w/o the Apple logo.
If boosted from an external drive, can't see the SSD from Disk Utility or Startup Drive options.
Occasionally, SSD shows up, boosts well, and functions well. But the computer crashes after a while and SSD disappears again.
Bad connection? Need a new SSD?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Hook it up however you installed the system in the first place (external disk drive, hard drive or target mode. Run Disk Utilities and see if you can repair the drive. This could be the hard drive cable, connection, corrupted system, or failing drive.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
To return a drive you'll need to contact iFixit directly. I'm just a volunteer who answers question. iFixit couldn't afford me ;-) So contact them here: http://www.ifixit.com/Info/contact
의 공유
I got some time yesterday to replace the MacBook Air 128 GB SSD with the original HD. The MBA works well with the HD. This indicates that SSD is malfunctioning. Since the SSD was newly bought and is still under the warranty, can you ship me a replacement? The cable might be bad. Thanks!
Order id: #232988
Order date: 02/07/2011
P.S. Since the SSD does not get read, the Disk Utility cannot even see it, not to mention repairing it.
의 공유
댓글 달기
답변을 추가하세요
davidwu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 9
전체 시간: 736
