주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 터치 바가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
How can I fix my screen wobble?
My 15” MacBook Pro Retina late model 2016 screen wobbles quite a bit. How do I repair this with minimal teardown? Any videos?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I have the same issue and I checked these screws… they are tight- I believe there must be some other screws under the black hinge cover- like in older models (e.g. my old MBP 2010). But I do not know how to remove this and if there are any at all? Because: the screen sits firm- it is only not staying in that angle - it moves loosely about 3cm back an forth… Thank you so much for your help. Leander from Berlin
의
댓글 달기
답변 2개
가장 유용한 답변
Hopefully the hinge screws are loose otherwise you’ll need a new display. Carefully pop off the bottom cover, then remover two plastic covers over the hinges:
이미지
Then you’ll need to check these screws:
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 달기
@leandermode - the hinge design in this series is very different from the older models. This series uses a press-fit pin into the upper lid case. The pin is keyed so its not free spinning and the clutch spring bites into it
이미지
The only correction is replacing the full display lid assembly.
이 답변이 도움이 되었나요?
점수 3
댓글 8개:
Thank you Dan for your answer… but… what a pity that there is no other way to fix this little issue (and as I believe quite common) … but by a complete replace of the display lid assembly. hmmm apple, apple….
의
@leandermode - Apple has reduced the serviceable parts down to a small handful ;-{
의
@danj do you know how?
Any idea if it's possible to remove the press-fit pin mechanism and transfer it to another assembly? My replacement part came without a hinge.
의
@sardar.lopez - What???
Clearly you got the wrong part as every one I've ordered have had the hinge pin and the hinge pieces as show in the pictures I've posted.
Here's the correct part: MacBook Pro 15" Retina (Late 2016-2017) Display Assembly At you can see in the iFixit parts picture the hinge is present on theirs.
I would love to know where you found this part and some pics as well.
의
I've got mine used from Amazon. It's the correct screen minus the hinge on the left. It's less than half the price so it would be worth the effort if it could put my paper weight of a MacBook Pro to use. Thanks for the reply.
Cheers
의
댓글 3개 더보기
댓글 달기
답변을 추가하세요
dusanbarisic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 3,457
