주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2.0GHz Intel Core 2 Duo T7500, 최대 4GB RAM, 15.4인치 TFT LCD 화면, 802.11a/b/g/n 와이파이, NVIDIA Quadro FX 570M(256MB) 그래픽 카드
No display on laptop
There is no display occurring on my lapty screen
beep sound are as follows
oneshort beep pause three short beep pause four short beep pause three beep
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
you may have errors with two things basically Dual In-line Memory Module
and system board check them if any one will found faulty replace the part
@nmitt start by connecting an external monitor and see if it displays anything.
Like when I plug my laptop into the charger, it doesn't work and the current is coming to the laptop but it doesn't work.
댓글 달기
답변 1개
That beep code symbolizes memory failure, and or video failure.
Replacing the RAM should fix your issue.
You have 2GB of RAM preinstalled unless you replaced it.
https://www.amazon.com/dp/B00C538B56
In that link you can buy a 4GB kit, of the RAM that your laptop supports and fits. It is actually more RAM than you have now.
2GB x2 sticks. Try doing so. Pretty cheap as its old ram models. Only 17$
Could be cheaper on EBAY as well. Just makes sure it is that. (The link I provided)
PS. This should fix and boost your Laptop.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nmitt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 26
전체 시간: 489
