주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Which component is responsible for connecting to the mobile network?
My iPhone 5c recently started intermittently displaying “No connection” in the top left. Resetting the phone would get it to work again. But starting from this morning, no amount of resetting or re-setting network settings has fixed it. Now that I’ve done “reset network settings”, it is stuck at “Searching…” as opposed to “No connection.”
So which component is the “mobile antenna”? Is it replacable? What connections can I clean or jiggle to ensure everything is solid?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Let's rule out hardware first as it's a common cause of the stuck on searching and no service problem.
Dial *#06# in the dialer and a 15 digit IMEI number should be displayed. If not there is a hardware fault relating to the baseband chip or circuit for it.
Check in settings > general > about phone for listed IMEI and modem firmware. If either fields are blank it's the same reason as above with hardware fault.
If it does end up being a baseband hardware fault it'll be too expensive to be fixed in my opinion. These types of board repairs can go upwards in the cost of $100 or more which is close to the cost of buying the same phone second hand.
해당 답변은 도움이 되었습니까?
점수 6
댓글 3개:
Thank you. Well bad news, I dialed *#06# and each time I press the call button, it darkens momentarily in response to being pressed, but nothing else changes on the screen. I guess this phone is a lost cause. I've done a hard reset but not a full software restore. Is it worth it? I'll probably try soon.
Oh I have reset network settings, and since then, in Settings, General, About, the "Carrier" is listed as Telstra 28.4. Is there any way it can get that info outside of the mobile connection? Eg. from Wireless connection, or the SIM card?
A full software restore may help but it may fail the restore with error -9 or -1 due to the baseband hardware fault.
댓글 달기
Hundreds of components are responsible for mobile connection. This is highly unlikely to be antenna issue as the iPhone uses 2 antennas to connect to mobile network since iPhone 4s.
Mad you said the display IMEI trick sometimes results in phone not responding. This is more likely to be baseband issue, which is a board level issue and difficult to fix.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
To rule out software, a full restore and set up as new to test connection will help to tell you definitively if it’s sn issue with the hardware. If it’s still searching after that.
To rule out SIM card - test the sim in another device (if you have access to one). Or try a new SIM card (you can get one at an Apple Retail Store or carrier store) and try to activate it.
If you want to open the device and test connections there, you can re-seat the coax cable that connects to the logic board. Sadly you can’t replace an antenna as it is built into the plastic enclosure of the device.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Cellular antenna actually _can_ be replaced, it's part of the lightning connector assembly and extends to 2 further small modules laying on the lightning assembly. You can see main part at step 33 of this guide, however, from the issue described, it's probably to be ruled out as a faulty antenna issue
iPhone 5c Lightning Connector Assembly Replacement
Thanks Bonnie. I can confirm the SIM card works in another phone as I'm now using it as a backup. I'm going to re-seat the coax cable, thank you. I'll also do a full restore.
Hello, I have a similar issue now on my iPhone 11pro, it says no service and also gets stuck on searching sometimes. Were you able to fix yours?
댓글 달기
귀하의 답변을 추가하세요
domarius 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 61
전체 시간: 1,079
