주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Medion Akoya MD96420 모델은 Medion에서 제조한 중간 크기의 노트북 컴퓨터입니다.
Horizontally Split Display Problem
My wife's Medion MD96420 laptop is displaying a horizontally duplicated screen (split screen appearance). It will only start in safe mode & will not connect to the net. The problem was intemittent and is now persistent. Any ideas welcome.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
I had a similar problem with my Medion MD96420 which was 3 months out of warranty. However, with a little research and talk around the office it appears that there is a problem with the video card whereby over time the heat weakens some of the solder joints and affects the video card performance. I contacted Medion support, provided proof of purchase and sent the laptop to them. After about 3 weeks it arrived back in perfect working order. That was just on 12 months ago and it has not missed a beat since. Before it was repaired I found that if I left it off for about 12 hours, when I restarted it would be ok for quite a while until it heated up and did the split screen thin again.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you Stephen. The computer is about a year out of warranty but I consider the fault a manufacturing fault after the information you have provided. I'll send the thing to the manufacturer and see what they will do for me for how much and post the result.
의 공유
댓글 달기
답변을 추가하세요
Ed1 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 37
전체 시간: 5,595
