주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP에서 제작한 레이저 프린터입니다. 12A 토너 카트리지를 사용하며, 5% 커버리지 기준으로 2,000페이지를 인쇄할 수 있습니다. 분당 15페이지(PPM)를 인쇄하도록 설계되었습니다.
Paper feed processing problem
My HP Laser Jet 1012 printer successfully prints a page, but will not feed through the printer entirely and a second page becomes jammed in the feed mechanism
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I was having the same problem and the iFixit diagnosis, i.e., that there was a problem with the pickup roller was correct! Here is a guide to cleaning or replacing your pickup roller from the HP web site: https://support.hp.com/us-en/document/c0.... My problem was solved just by removing and cleaning it.
의 공유
댓글 달기
답변 2개
선택된 해법
I believe there are maintenance kits for these models which are usually expensive, but more times than not it’s the pickup roller. Try another toner as well. I have seen in certain printer models where the toner can cause jams.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The User Manual (which you can get online) recommends:
  • Cleaning the pickup roller with a lint-free cloth and rubbing alcohol. Just tried that and it enabled my printer to grab 3 pages one after the other (instead of jamming after just one).
  • Alternatively, replacing the pickup roller. I see you can order some on Ali Express. Haven't tried that yet.
In the meantime, a temporary solution is to stand by the printer while it prints and manually load one page at a time.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I replaced pickup roller $25 and still have same problem. Now thinking it's sensors, in which case, probably bye-bye printer. Otherwise, this printer has been the best tech investment ever in terms of stability, function and reliability, so missing in other gear.
의 공유
댓글 달기
답변을 추가하세요
Ellen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 50
전체 시간: 2,761
