주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Neato Botvac 80은 2014년에 출시되었습니다. 부품 번호는 905-0079입니다.
Neato Botvac D80 issue.
I own 2 of these units (identical). By swapping a couple parts I have determined that the battery, and charger base are not the problem. Bad unit has no power at all. If I put it on the base to charge, Home button lights up green, tells me to turn the switch on (it’s already turned on, but I press ok anyways). Home button turns to amber (slow blink to indicate charging has started). After between 10-30 seconds, it changes to rapid amber blinking on home button and after about 3 seconds it shuts down, reboots and starts the process all over. Ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개:
Hi Jeff, got the exact same problem. Figured it had to be a faulty on/off button so I swapped it for a new one, only to find out that was not it...Did you ever find out what the problem was?
댓글 달기
답변 1개
I just successfully repaired a Botvac D85 that had a similar issue. I connected my computer to the USB port and saw an error flash that said the battery was overheated. This caused the main board to automatically power off. The root cause for mine was the Fuel Gauge IC. It took a hot air station and some patience. You might give this article a look. http://www.robotreviews.com/chat/viewtop...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jeff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 1,111
