주요 콘텐츠로 건너뛰기
The Alienware 17 R4 (17.3 inches) is a gaming laptop, released by Dell in 2016. (AW17R4-7000SLV-PUS)
My fan is making a loud grinding noise
My fan is making a grinding noise. I believe the bearing is bad in it as it doesn't want to spin like the other one. When I have the Bottom cover off and I turn it on, it's struggling to spin. How can I go about removing that fan and replacing it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi @kstorm
Well, I would suggest you to follow the below link to remove the parts
Alienware 17 R4 Battery Replacement
Follow to step 23.
The fan should be holding by with some screws.
remove it and use it as a reference to compare and order replacement.
You can purchase replacement fan at ebay, aliexpress, etc
Example:
https://www.ebay.com/sch/i.html?_from=R4...
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Hi @kstorm ,
Just to add to the answer, here's a video that shows how to remove the fans.
댓글 달기
답변을 추가하세요
Kyran Storm 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 36
전체 시간: 8,075
