Cooling issue Samsung rs263 fridge
I have a fridge that has stopped cooling. The details are as fallows. A few days ago I heard the fridge condenser fan being a little noisy. I new it was time to take it a part and defrost the fridge. This is normal for this model and something I have gotten used to. After completing this I put it all back together and it cooled down normally and I though things were going to be good for 4-6 months (Had to do this a lot).
The next day I had noticed the freezer has stooped cooling, which has never happened in all the time Iโ€™ve owned it. Where Iโ€™ve had to take the fridge apart, maybe 15 times, the freezer has always been fine. So I cleaned out the freezer and took off the panel to find nothing wrong and dry coils. I was stumped. At this point the fridge was good. I took the rear panel off to check the condenser coils. I cleaned them but they were not that dirty.
I took the fridge section apart again thinking that even though none of those wires should have anything to do with the freezer, I was out of ideas. All was fine in there accept a slight bend in the copper tubing to the evaporator, which I bent back thinking maybe I caused a kink when cleaning, or worse, broke it and caused a leak. There was also frost already at the top of the evaporator coils.
The next day I noticed that the fridge was nolonger working, so both sides were doing nothing. I took the fridge apart again and saw the frost at the top of the coils and took a temp readings of about 25f there but 50s anywhere else on the coils. (Room temperature is 50.
So I donโ€™t know where to go next. Upon plugging it in the condenser kicks on after a few seconds and continues to hum until unplugged. Saying to me that the temp controls work as well as the relay and condenser. The evaporator fans on both side work, I here liquid moving around in there so I donโ€™t think it has leaked out. The condenser fan comes on but only stays on for a few minutes when plugged in. I wasnโ€™t sure about that being a problem so I tried laying a tower fan down next to it on high as a substitute, but it was no help.
So there is my long story about my broken fridge. I thought the details may help zero in on something. Iโ€™d appreciate any advice.
UPDATE:
I pulled the start relay off the compressor as I saw advise to check if it rattles. It does. Not 100% sure as it is a slight rattle. I wondering if a good relay should be 100% silent as you shake it. I decided to test things as I read about the compressor humming but not actually kicking on. I measured the compressor for resistance, this is my major concern. The info Iโ€™ve seen says the readings should be 10, 6, 4. All three readings were about 8.4. I fear my compressor is bad which would be the end of the fridge. So is my compressor bad or should I order a new start relay?
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
