What to do is xbox gets wet
What would I do if I spilled a liquid on my xbox? Is it repairable?
좋은 질문 입니까?
좋은 질문 입니까?
It depends.
1) Did you turn on your Xbox after you’d spilt a liquid on it? If yes, than repairability decreases by a huge margin.
2) Did you disconnect Xbox from a wall power after accident? If no, than chances of successful repair are going down again.
3) How much liquid got inside and what internals did it touch? If nothing crucial, you might get a chance at restoring most of the functionality of your Xbox. But again, that depends.
I’d suggest carefully prying your Xbox, disassemblying it and giving it a good alcohol bath or clean everything with alcohol (Ethanol 95% is the best for this, but other types of alcohol that do not have anything but alcohol can work, too). And after good cleaning you can try to give it a repair technician, so that he/she could check everything for additional damage that can be prevented before turning on the system. That can increase success rate by a decent margin. Good luck!
해당 답변은 도움이 되었습니까?
First replace the PSU, because it handles 100-240V, it is a real safety concern after water damage.
Then clean and dry out all components and inspect for damage.
Honestly water damage is not DIY repair.
해당 답변은 도움이 되었습니까?
You should leave the Xbox without turning it on for a few days and then wipe down all remaining residue with a microfibre cloth if you don’t wan to to open it up.
If you do open it up, then you should wipe the insides down with a microfibre cloth, reassemble it, and hope for the best.
If that does not work, try troubleshooting.
If THAT doesn’t work, then you might need a new console.
해당 답변은 도움이 되었습니까?
24 시간 전: 5
7일 전: 20
30일 전: 102
전체 시간: 13,251
댓글 1개
What do I do if a little bit of water get in my xbox one s
Tehron 의
