주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/32/64/128 GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
Random reboot (kernel panic) and wont charge battery
Hi,
after discovered the minijack connector broken on my iPhone SE, I’ve ordered a new lighting/headphones cable to fix it.
Once I’ve installed the new connector board, I’ve found that the phone was unable to reveal and charge up the battery (it shows 0-1% charge level on startup and correct charge level after few seconds) and also randomly reboots after one or two minutes of use.
I’ve found one kernel panic log file for each random reboot, with similar content to this: https://discussions.apple.com/thread/795...
After some research online, I thought it was a battery problem (which was already quite worn before I’ve opened the phone, even if it had never given similar problems), so I’ve ordered a new battery.
This evening I’ve installed the new battery, but I’ve found the exact same issue.
I’ve also tried to swap in the old lighting/phone connectors board and also leave it unplugged. I’ve tried also to unplug front and rear camera, touchid… no matter what I try to do in order to isolate and find the problem. The exact same behaviour happens.
This evening, after backing up the last photos (it’s impossible also to backup the whole phone via iTunes, because the phone resets in kernel panic after few second from the backup start), I’ve tried also to do an Update via DFU, and a full restore, in order to exclude software problems.
Nothing, same issue still here.
The absurd thing is that every single function of the phone seems to work without any problems (including all the replaced connectors and all the devices that are served by that connection).
I have been unable to isolate the problem. Don’t know what I can try to do now to recover it. It’s totally unusable.
Do you have any idea of what happened and how to (try to) fix it?
Thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
It’s possible you damaged the logic board during your repair. There are some tiny components surrounding the battery and Lightning connector that can easily be damaged when prying off the connectors.
Next to the battery connector, there are four tiny components, one of which allows the battery to communicate the charge state to the CPU. Getting a reading of 1% is a typical symptom when that component is dislodged. Additionally, surrounding the Lightning connector are dozens of tiny components. Do a thorough inspection of the are and look for fully or partially dislodged components.
If you find anything amiss, then it will have to be repaired by a shop that does micro-soldering repairs.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
Strange (I usually do electronics repairs and already opened +20 phones without any issue), but even possible...
I'll verify again today the components surrounding the connectors.
However, the behavior seems very strange to me.
Thanks!
You were right!
Analysing the board under the magnifier I've found a tiny component (maybe an smd resistor, 01005 package, 0,4mm long) out of place, just next to the battery connector.
Since I've already soldered many tiny smd components, I've tried to resolder it in many ways with my air station, unfortunately without success.
Afterwards I've lost the microscopic component :(
(Not 100% sure that this is the only issue, but probably...)
Thanks for the advise.
Which one is missing? Take a look at the picture I added to my answer and let me know.
댓글 달기
답변을 추가하세요
Edoardo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 3,661
