주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년에 출시된 Samsung WB350F 카메라는 21배 줌과 Wi-Fi 기능을 갖추고 있습니다.
Why does the setting dial sensor seem bad?
The camera works great except the dial to change the setting must have bad sensor or something, because it just jumps to an adjacent setting and right back to Auto (where I have it) in the course of a second., without me touching the dial. It happens randomly during regular handling and interrupts videos. Any ideas what might be wrong or how I can fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
The mode wheel usually consists of 2 or more metal fingers that slide over gold plated segments on a circuit board as the wheel is turned, so making contact with different circuits to select the different modes. To be realistic, your best bet is to put a watch on eBay for the same make and model of camera offered as “spares or repair”, but with a different fault. They go pretty cheaply. Practice disassembly on this, following whatever guides and videos you can find online. You should then be well placed to install the necessary parts (probably the entire top panel) on your camera with a spare from the one from eBay. If you like, you can then try taking apart the dodgey mode wheel from yours - it may be a destructive process - to see what’s inside and whether you might have been able to fix it, perhaps by increasing the pressure of the fingers or cleaning the tracks.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Remove the battery, then squirt some rubbing alcohol underneath the dial (wet a cotton ball with the alcohol, then squeeze it out inbetween the dial and the camera body, or use a syringe), or use a spray can of electronic contact cleaner. To make sure the rubbing alcohol gets in there, you can widen the gap between the dial and the camera body by inserting a fingernail inbetween, but don’t overdo it or else something might break. Once you’ve got the rubbing alcohol in there, rotate the dial a bunch of times to work the alcohol inbetween the metal contacts inside the dial mechanism to clean off what seems to be oxidation on those contacts. Apparently the contacts oxidize quickly—maybe the manufacturer “forgot” to apply a gold surface layer to them. After you squirt in the rubbing alcohol, wait about fifteen minutes before you reinstall the battery, to let the water in the rubbing alcohol evaporate, or else it might short out some electronics inside the camera and fry it. Preferably use 91% rubbing alcohol instead of 70%, since 91% will introduce less water into the camera. This process works for many people, but not everyone; when it does work, it might be only temporary for some people, at which point you can do it again.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Perfect, it works
의 공유
I did and its work great but few months later the problem can be again so don't worry and clean it with alcohol again
의 공유
댓글 달기
Alcohol helped mine too, but it came back. I wonder if you could bypass the wheel with a small dab of solder? Would be stuck in one mode, but at least the camera would be usable.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
John Swierczek 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 59
전체 시간: 1,789
