Front facing camera not working after back glass replacement
Hello! I replaced the back glass on my iPhone 8 yesterday. This was the second time I’ve done it (first time was for a friend). First time it took about 2.5hrs, and there were no functionality issues after the repair. So this time, I replaced the back glass and it took just under 2hrs, but the front facing camera is not working. The proximity sensor, earspeaker, and ambient light sensors all work. Is it possible I damaged only a portion of the cable that connects the front facing camera? Not sure if the cable or components are exposed from the rear of the phone. I was using flat safety razor blades for the removal, but did use an x-acto when removing small bits of glass near the camera. It is possible I could have poked something around there perhaps.
Should I start by replacing the front facing camera/ribbon cable? Or is there something else I should be looking for? I used double stick tape to hold the back glass in, while I sort the camera issue out. So I can easily pop the back open to take a look if need be,
Ps. To those who don’t already know: the back glass repair is very annoying, and risky. I’m definitely never doing it again. BUT, if you are going to do it, make sure the razor blades you use are high quality. This second repair went way quicker because the quality blades weren’t breaking and dulling nearly as quick as they did on the first repair. And of course, were gloves and eye protection. The glass bits really shoot out of there.
Thanks!
좋은 질문 입니까?
