주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.4GHz 또는 1.6GHz 프로세서 / 64GB 또는 128GB SSD
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
이미지
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
이미지
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 11개
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see 기존 질문에 이미지 추가하기
의 공유
try a different dc in board
의 공유
What’s that involve, is it doable myself?
의 공유
the i/o board guide that trevor posted
의 공유
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
의 공유
댓글 6개 더보기
댓글 달기
답변 1개
가장 유용한 답변
Two possibilities:
Most likely possibility: bad battery
MacBook Air 11" Late 2010 배터리 교체
MacBook Air 11" (Late 2010) Battery
Less likely possibility: I/O board
MacBook Air 11" Late 2010 I/O 보드 교체
MacBook Air 11" (Late 2010) I/O Board
Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports. 이미지
제품
$29.99
Replace the 4790 mAh battery compatible with MacBook Air 11" (2010). 35 Watt Hours (Wh), 7.3 Volts (V). 이미지
제품
$57.99
MacBook Air 11" Late 2010 배터리 이미지
안내서
난이도:
조정
15 minutes
MacBook Air 11" Late 2010 I/O 보드 이미지
안내서
난이도:
조정
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
andy hawkins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 18
전체 시간: 495
