주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
Dirty Ports?
There is a lot of buildup of dirt on the case where it recesses into the port openings. Is it a problem and what is the best way of cleaning it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
I used a blending/ fluffy make up brush and that did the trick. Soft, clean and easy to get. I found it easier to use then the q-tips
댓글 달기
답변 6개
선택된 답변
use q-tips or compressed air to try and clean the ports
as for it being a problem there shouldn't be one as long as it doesn't mess with the connection
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Its too stuck for compressed air but i will try the q tips
댓글 달기
If the muck is really stuck on, you can use a small amount of alchohol on the Q-tips to help unstick it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Q-Tips or dry cotton wool should clean your ports well.
As for the mag-safe charger port, the magnetism can hold some dirt to it. This can be hard to remove but Q-tips and a little extra effort should clear it out
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
A soft toothbrush can be used to loosen debris, then use a little compressed air to blow it out. If you are going to use alcohol, be sure to remove the battery first, to avoid shorting anything out.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I advise against alcohol, if it get's in the port- your port may end up permanently screwed. Ditto at the compressed air though.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Used a clean make up brush and that did the trick of removing any sand, dirt, lint from the charging port
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
AussieMac 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 16
전체 시간: 11,301
