Dirty Ports?
There is a lot of buildup of dirt on the case where it recesses into the port openings. Is it a problem and what is the best way of cleaning it?
좋은 질문입니까?
좋은 질문입니까?
use q-tips or compressed air to try and clean the ports
as for it being a problem there shouldn't be one as long as it doesn't mess with the connection
이 답변이 도움이 되었나요?
Its too stuck for compressed air but i will try the q tips
If the muck is really stuck on, you can use a small amount of alchohol on the Q-tips to help unstick it.
이 답변이 도움이 되었나요?
Q-Tips or dry cotton wool should clean your ports well.
As for the mag-safe charger port, the magnetism can hold some dirt to it. This can be hard to remove but Q-tips and a little extra effort should clear it out
이 답변이 도움이 되었나요?
A soft toothbrush can be used to loosen debris, then use a little compressed air to blow it out. If you are going to use alcohol, be sure to remove the battery first, to avoid shorting anything out.
이 답변이 도움이 되었나요?
I advise against alcohol, if it get's in the port- your port may end up permanently screwed. Ditto at the compressed air though.
이 답변이 도움이 되었나요?
Used a clean make up brush and that did the trick of removing any sand, dirt, lint from the charging port
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 11,345
댓글 1개
I used a blending/ fluffy make up brush and that did the trick. Soft, clean and easy to get. I found it easier to use then the q-tips
emita_sakura 의
