If your Kenmore 110 Series Washing Machine refuses to spin or agitate during the wash cycle, see the Kenmore 110 Series Washing Machine Doesn’t Spin or Agitate problem page for possible causes and solutions.
See if this video will work for you. Giving us your specific model number may help.
https://www.youtube.com/watch?v=j4NIwGdr...
Turn off your washer and unplug it from the wall. Lift up the hood to reveal the washer tub and agitator.
Remove the agitator cap. Depending on your Kenmore model, this can be done in one of two ways. First, try to unscrew the cap counter-clockwise. If this doesn't work, look for the line that separates the bottom of the cap from the top of the agitator. Gently press a screwdriver into this joint and pry off the agitator cap.
Remove the agitator bolt. As in Step 2, how you do this depends on your Kenmore model. Some Kenmore washers have a hex bolt that holds down the agitator. Remove this with a socket wrench. Other models use a plastic screw with a square insert in the center. Remove these type of screws by inserting the end of a large, flat bladed screwdriver into the hole and turning counter-clockwise. You can also use the square end of a socket wrench.
Put on the safety gloves. Take your hands and place them beneath the agitator, one on each side. Keep your head away from above the laundry tub and turned to the side. Then tug on the agitator. Keep your head turned so the agitator doesn't hit you in the face if it suddenly pops off. Because of the action of water, temperature and detergent, sometimes these agitators can get stuck and be quite stubborn to remove. There are a couple of tricks you can try if this is the case. First, take a small block of wood and hold it over the agitator hub. Tap this a few times with a hammer. This should loosen the hub. Another trick you can try is to plug the washer back in and run a cycle on the hottest temperature. Allow the washer to fill up halfway, then stop it. Try to remove the agitator. Hot water causes the metal to expand and hopefully, this will wedge your agitator off the hub.
댓글 2개
Every washing machine with a DIY agitator removal video has a 7/16" nut. But not this one. When I figure it out, I hope to post a solution. Nothing posted here is useful.
UPDATE: The "nut" is a plastic piece directly visible from above: "Washer Agitator Spring Retainer WPL-WP3946995"; the axle it's threaded over is also visible from above.
A 1/2" square drive ratchet extension removes it easily. Wow. I'm living in an alternate dimension. This repair seems too simple.
Eryk Stacy 의 공유
I literally use a wrench with long socket ! To reach it once i get the exact one I’ll comment again with the right size
Yamil Lopez 의 공유
