주요 콘텐츠로 건너뛰기
Samsung Galaxy J3 V는 2016년에 출시된 저가 스마트폰입니다. 이 제품은 후면의 5 megapixel 카메라와 전면의 2-megapixel 카메라를 포함합니다. 5인치 HD super AMOLED 스크린을 장착하고 있습니다.
21 질문 전체 보기
I dropped my Galaxy J3 in water an hour ago, and it wont turn on
So, I wasn’t paying attention and my hand slipped. The phone hit the side of the sink, back popped off, and the battery came out. They were submerged for less than 5 seconds before I fished them out. I dried them off with a towel, waited a few minutes, then popped in the battery and tried turning it on. It vibrated like it usually does when I boot it up, however the screen stayed blank. Is there any way for me to easily salvage this? I really don’t want to have to get a new phone.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
Water damage repair is never easy.
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
Samsung Galaxy J3V
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
It's Nep 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 1,119
