주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac G3는 귤, 블루 베리, 라임, 포도 및 딸기 색상이 있습니다.
iMac sortof powering up
My iMac G3 was working but now isn’t. It’s exhibiting bizarre behavior so I’ll be specific. When I plug it in I can hear a faint high pitch whine from the inside. Pressing the power button results in it glowing amber, the hdd spinning up, then the bootup chime. The display does not come on. Shortly after the chime there will be a sort of thunk then the power button will turn green within a blink of an eye the whole thing shuts off. It won’t even think about showing signs of life afterwards. The only way to repeat this is to leave it unplugged for an amount of time. When I plug it without doing anything else the lights will slightly flicker so I think something is happening.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The first thing I would do on this one is the put in a new 3.6 volt 1/2 AA PRAM battery. To do that you need to pull the logic board. Here’s the guide. You can see that battery on step #8 of the guide, sitting right on top in the middle.
iMac G3 모델 M4984 로직 보드 교체
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Owen Davis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 14
전체 시간: 356
