One tail light does not work
One tail light does not work - replacing bulb did not correct the problem.
좋은 질문입니까?
좋은 질문입니까?
If the running light works but is dim, have someone hit the brake. If the dim light goes out, you’ve got a bad ground. Check the metallic connection from the bulb through the socket into the body or wiring. Rust right at the socket is pretty common, scrub it shiny, put a light smear of grease to suppress later rust. You can try taking a piece of wire, hold one end to the socket contact and find bare metal with the other. A dim running light will brighten up to normal confirming bad ground.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 569
